Help Text Message Notification Sound
garak0410
The sound for my text message notification has gotten very quiet lately..I've checked all the proper volume settings and they are set to max yet the alert for text messaging is very quiet...and I've rebooted the phone with no luck...any other place I should look or is this a known issue?
try menu>settings>sound>volume see if your notification volume is set differently from your ringtone.
You might also try downloading an app called "Quick Settings"
I found the included Android volume control a little lacking, but Quick Settings lets me independently change volume settings for: ringer, notification, media, alarm, voice call, and system volume.
It's a free app as well.
This app did it...while Android was showing my notification volume at 100%, this app showed it down to like 30%...thanks!!!!
