Root Text Messages Vanishing...???
I am on the .595 GB leak and running the Zombiestompted 1.7. (Also I am using Go Sms Pro, if that has ANYTHING to do with this at all.) I will receive messages fine. They show up in the notification bar, but when I click on them and it takes me to Go Sms Pro they are not there...instead of the latest message appearing at the bottom it will be a message that I had received earlier...any thoughts?
I just checked the stock .595 text messaging app and all of the messages are there and in their correct places...is this just that Go Sms Pro doesn't like GB or what?
That might be your problem. I would uninstall GO SMS and then reinstall it. See if that helps... if that doesn't head on over to Handcent or to stock ( right now I'm using stock because handcent seems slow on GB)
