Sorry for my ignorance, I just switched from an Iphone to a note. Im not getting or sending texts, is there a set up i have to go through in order to start texting? thanks in advance
did you just swap in the sim card or did you get a new one and activate it? i just switched from a ip4 also and had to get a new sim card but if you had a 3g or 3gs they had the old bigger version sim cards. should be no setup at all contact att imho.
