Help Text messaging icon not going away
On my LG Lucid whenever I get a new text, the icon next to the user still says 1 or 2 or 3, depending on how many texts they have just sent.
Does anyone know why this is happening?
I just recently updated my phone to the ICS software too.
Thanks!!!
It may be an option in the messaging app (to show unread texts). If that's not it I would say try clearing the cache and data and seeing what happens.
I cleared the cache last night and it seemed to be working fine, till this afternoon.
I just gave up and downloaded the Handcent SMS APP and it works perfect!
All these problems started happening since the ICS update :(
The ICS upgrade is more like a DOWNgrade
Unfortunately we hear that a lit about upgrades....it will fix some things and sends others into never never land. I'm glad to hear you like handcent as a replacement. Don't forget to turn off the notifications for your stock messaging app so you don't receive duplicate notifications. :D
You're only turning off the notification, not the entire messaging app. Handcent will notify you of new texts.
