Did you delete conversations.apk by any chance?
No, and I tried reinstalling it just to be sure...same problem still, i select "text messaging" and all that happens is a blank screen and then back to my home screen
Did you delete apps, freeze them or rename them? Are you using 2.1 or 2.2?
I'm still using 2.1 and I deleted apps...also I made sure to practice reinstalling any system app I deleted so I'll be fine to update to 2.2...so I'm a noob, just not a complete noob
Did you keep a list of what you deleted? When you go to reinstall them they need to be put in the right folder and given certain "permissions" for the system. If I remember correctly one of the social apps will mess up texting if removed.
Email engine is the one causing the problems with text messaging. You need to reinstall it.
Problem Resolved! ...and that is why this website is the best...because of smart people like you helping dumb people like me
I guess I''ll have to be a little more careful with what I delete from now on lol
OK, and how do you do that? I can't find anything on google. My text messaging app keeps crashing and it is driving me F#&^ING CRAZY!Email engine is the one causing the problems with text messaging. You need to reinstall it.
