celticfc482
Member
Im finding that with text messages , quite alot of the time the notification doesnt pop up and it doesnt show i have a text unless i go on the messages app, you can see how fustrating this is, people texting and i have no clue unless i open that, i checked all the settings and its all set up fine?
Any idea whats wrong, if not can you recommend another app which works fine, il try that?
thanks
thanks
