I've been having trouble with my text message tone for several days now. I wanted to use the same tone I had with my previous phone which is from zedge. For the first couple of weeks it worked fine.
Then I heard there was an app available to disable that stupid default ascending ring that the phone came with so I downloaded it. That is when the trouble seemed to start. Every since I changed the text tone the phone has always vibrated along with the message tone even though vibrate is not checked. That's a separate issue that others have complained about also.
Around the same time I downloaded the Battery Notifier app so I could get an audio tone along with the green light to let me know the battery has charged. I used the same tone I had for texts just for consistency. That worked fine.
The problem with the text tone is either I won't get anything but the vibrate, I get a quick incomplete tone & incomplete vibrate, or nothing at all. I've tried to change the tone back to one from the phones default list but it's still the same thing. I've uninstalled both the Disable Ascending Ring and the Battery Notifier apps so everything is back like it was but it still doesn't help. I've rebooted the phone but it doesn't help.
The whole text message notification system has seemed to go haywire. Any ideas?
