Text To ???
shawn418
I'm using Handscent for text. Is there an app that will transfer to email or word so I can print them?
Thanks in advance.
An app in the market called SMS Backup will automatically save them all to your gmail account in a folder called SMS
Thanks in advance.
Thanks in advance.
If all you want to do is print the text then try PrinterShare from the market. You don't even have to convert them to Word, you simply print from the phone and goes to the printer. Works pretty good, been using it for a while.
