Texting error from 9230, 2112 error?
Idleisaac
I'm getting a "You rced this message because you sent a text to a number without the area code or used an invalid short code msg 2114." text when I send a text to ANYONE in my contacts, it just started about 3 hours ago when I woke up.
I've even tried texting though the default program, GoSMS, and a free-texting program called "HeyWire", and I still get the message. (I even tried texting my phone's number through HeyWire, still got the message)
Things I have tried:
  • Turning off phone, taking out battery for a few minutes then rebooting.
  • Turning off phone, taking out battery and SD card, putting them back in, rebooting.
  • Erased all of my text conversations.
  • Erased all Dialer & Dialer Storage data.
  • Backed up all of my contacts, then erased them from my phone, then tried texting one of them with just the number (No longer a contact)
  • Tried texting while on 3G/WiFi.
    None of those worked, and I've tried each multiple times. I"m still able to connect to 3G/WiFi, but for some odd reason I can't connect to the internet with 3G,,,​
hmmmmm odd. what phone do you have? have you tried updating your prl and profile? should be under software updates in your phone's settings.
and maybe call your carrier and let them know about your issue. it could be a network issue that they need to know about if not already.
