Tf700 Bluetooth and Airplane Mode Problems after JB update
Wade2
New to this site but have done days of searches for my problem. Since JB update my bluetooth is not working and I have also found out Airplane mode is messed up also. Both will have slight responses for a short time after booting , then nothing. I down graded back to ICS and I get some functionality and have actually paired a device but does not work correctly. Asus wants the tablet sent back , but it sure seems to me as it is Op system causing all of this. It was working fine before. I am new to messing around with android , So one question is since I down graded to ICS 4.0 does the actual device firmware downgrade completely also ? I see that Bluetooth Version lowered and other versions lowered , but could something else not get back to that version , some type of Bios type settings? ( I was told no Bios in android ,but is there something like it ? )
So does anyone have the same problems , any answers or thoughts ?
Thanks
You may not like the answer, but if you have not already done this you may want to try a Factory Reset, then reinstall JB and do another factory reset. You will lose your data and apps with a Factory Reset.
Good luck1
