Help The "Droid" Audio No Longer Plays
ptco911
It is nothing major but the "Droid" audio no longer plays during the boot up cycle. Is there any way to correct this?
Is that sound considered a "notification"? If you silenced or changed your default notification, that could be the problem. I noticed the same thing with mine, but I ended up doing a factory reset (unrelated), and never changed my default notification from the "Drooooid" sound it's set to, and lo and behold, I'm getting the sound when I boot up again.
if you use sound manager, i believe it's either the "system volume" or "media volume" that change its vol
I've noticed mine doesnt play on ocassion, maybe its a bug. I dont really care though lol
