Root The FPS fix with Unrevoked
Do you mean it keeps going into reboot mode? The main screen when you do a volume down/power on? I had that trouble all day yesterday. You have to make sure you wipe the cache and the Dalvick? cache then install from SD card and you will have no problems....to get out of there if you can get to the recovery screen do a wipe and then restore from nandroid...
-Art
no, it would reboot fine. when the home screen of stock sence would come up, i would try to slide the lock screen down but i wouldnt slide down. i have to take out the battery. but ill try the cache wipe. thanx!!!
didnt work : ( it boots fine but when it's done & the Sence slide bar is up, i cant slide it down & where it says Sprint it says "No network" I have to take out the battery & flash stock Sence to get it working again. :/
jdidnt work : ( it boots fine but when it's done & the Sence slide bar is up, i cant slide it down & where it says Sprint it says "No network" I have to take out the battery & flash stock Sence to get it working again. :/
Same here. I had to restore my nandroid backup (i now fully understand why one need to do a nandroid backup before flashing Rom/kernal).
Came from BakedSnack1.7, had fps uncapped built in but I couldn't get wifi tether to work. I'm currently on Fresh3.2, wifi worked but fps capped at 28.
