A
Android Question
Guest
hi everyone,
I was using a 32GB card samsung Galaxy 3, until ....
A few days ago I noticed that an Alert appeared "card was removed" i didn't do anything about it because i had a busy day.
Today I wanted to listen to some music that on the memory card the card doesn't show on my device.
I also looked through settings and even through the app I regularly use x-plore, but there is no indication that the card is connected to the device.
I tried to pull out and push it in, restart the device but nothing happened - even the message "preparing card" did not appeared.
I tried to plug the card to a computer through a few USB adapters and also through a card reader, i even connected through a USB adapter to the radio system in my car,but no change.
Now I understand that it's likely the card is a wreck, but I have a fraction of hope that at least i can pull the files out from the card (without formatting)
I searched the web a bit but have not found the same glitch I experienced, and if i found, there wasn't a solution to that post.
could someone help me to find a solution to the problem, the information on the card is very important to me.
Only without the ******** comments like "I have a solution! Throw it away!"
