Help The MOST ANNOYING THING!!!
I dont know why I keep getting the "Insufficient Storage Available" I did the researched and tried everything. I dunno whats causing it. Stock rooted rom. I have plenty of memories and storage left.
I feel like my apps are causing this...but how do i find out which one is causing it? The last thing I installed was Go SMS Pro and thats it.
How much is plenty? Also, keep searching the S3 forums- I'm pretty sure I've seen this discussed before...like here:
http://androidforums.com/metropcs-g...ot/701410-insufficient-storage-available.html
10gb in my internal storage and 17gb in my SD Card.
And Yes I read that thread. In both of my storages, I dont see any .odex file under Data or Application.
Sorry I can't be of more help, but a Google search for "Insufficient Storage Available galaxy s3" turned up tons of stuff, both on this forum & others...your answer is out there somewhere. Hopefully you'll get some more comments to this thread too...
Oh- and if all else fails, go ahead & back up your data via something like Kies & do a factory reset- a little bit of a pain, but it usually clears up these kinds of quirks. :)
Try a full wipe and re-flash of the rom and see if that helps.
Off topic: this is what I thought of when I read your thread title :D:
What carrier are you on? The reason I ask is, I would like to move this into your carriers root forum:)
Have you tried to clear cache and dalvik cache from within recovery?
Hahaha nice one Brian!
Yes I went into Recovery and actually cleared cache and dalvik cache and nothing.
Last time it happened, I just cleared and wiped everything started fresh so ill just do that i guess...a pain in the butt tho.
I have Verizon.
I have Verizon.
I suppose you could always try reflashing the ROM without doing a factory reset (just clear cache & dalvik) & see if that helps before you choose the "nuclear"option of a full reset...
