Help The (Possible) Main Issues and How They Can Be Fixed
daivik
Hi, my GSII is arriving on Monday.
SO I just wanted to make a thread, about the possible issues that some of the GSII units are having, and whether they can be fixed, need to be "waited out", or a replacement is in order.
I know of
1) GPS issue - Most people say this seems to fix itself after a few days, IF the problem was even there in the first place.
2) Jumpy signal - Does this actually impair usage of phone?
3) Wifi signal - Some say their unit has very bad wifi signal? Is there a fix, or is a replacement in order, or does it appear to fix itself?
4) Delays on wake up time. Fix? or Replacement?
I know that out of the all the GSIIs sold only a minute portion will have these problems, but if mine has any of these, I would like to know what action to take as quickly as possible so I'll have a properly working, BEASTLY phone all the sooner.
I know it may sound a bit picky, but I'm not expecting a 100% perfect phone, because it is more than made up for, when the device is properly working, because it's just such a beauty of a phone.
Also I think if we can try to keep this thread on topic and "concise" (unlike what I have done in this first post :(), it'll be a good thread for new GSII users that won't have to read lengths and lengths post before the can find out what/if anything is wrong with their device.
Add any solutions or issues. :)
Random Rebooting seems to be one a few people are having. It's only happened to me twice so far and it doesn't seem to be a full reboot.
One other problem i've had is when i leave the house the phone switches from wifi to data normally but when i get back it doesn't pick up wifi and the phones data doesn't work either. The only way i can fix it is by switching wifi off and back on. Don't have this problem with Hero and Milestone. I also find both wifi and 3g to be weaker than my other phones.
5) heat issue.
its suppose to get warm/hot....but too hot to hold is a throw back IMO. would be good to have a mesure, like if it goes over (example:)35 degree's...its a send back.
From my phone ownership......
1) GPS issue - Most people say this seems to fix itself after a few days, IF the problem was even there in the first place. Not had that issue locks on in under a minute
2) Jumpy signal - Does this actually impair usage of phone? You mean network signal? Put the phone on GSM only network
3) Wifi signal - Some say their unit has very bad wifi signal? Is there a fix, or is a replacement in order, or does it appear to fix itself? Hopefully Samsung will address this issue as they do know about it
4) Delays on wake up time. Fix? or Replacement? Not had that issue
The red spot when using the camera, I've got a Tmobile S2 and when I connect to Kies, there isn't an option to update firmware. Its states:
PDA:KE3/PHONE:KD1/CSC:KE3(TMU) is the latest firmware.
Miss Diva
If the GPS issue us about how long it takes to get a lock, it could just be that the GPS is starting from cold, thus taking longer to connect, and people could be getting confused by the "unable to locate" message.
Logically, if you get the message then hit the "my location" button again, then your restarting the GPS connection sequence, and losing any progress on the connection.
Try pressing my location once and waiting a few minutes, ignoring the unable to locate message, this may get you a lock faster from a cold start, just guessing though.
Miss Diva
Yes, miss diva, we're at a loss. Every single update, even small ones have to go through T-Mobile first. And the chances are, are that T-Mobile won't even bother with half of them. ;(
That might not be 100% accurate. You might be able download official firmwares and flash them through odin, if you know where to go that is ;)
Not at all
When you get an update through kies, or over the air, the update is downloaded and 'flashed' to your phone, 'installed' may be a better word if you like.
Using odin does the same thing, just you have to find the firmware to flash into your phone. It takes a little know how, but it's easy to learn.
Rooting can also be done using odin, just you install a different file, as oppose to the original firmware. Once rooted, you have access to a recovery screen on boot, by way of a combination of buttons (same as accessing download mode) where you can install other mods/firmwares/kernels designed to run on your phone.
Not at all
So I'm not gonna root because I really don't want to jeopardise my warranty (because it's really good - next day swap out at my door). But I can use odin to install the updated firmware?? (This won't have T-Mobile bloatware on it will it??)
And what would this do to my warranty situation??
And what about my settings/data/apps data?? Will that be lost if I flash a new firmware??
Thanks for the help btw :)
I seem to have KE2 on my phone. Are there any other versions in between the 2 and the 7, or does it just jump to KE7 with the update? Im asking because Kies is not informing me of any updates.
Also, I heard that 2.3.4 has been released, it just doesn't seem to be available for all users.
2.3.4 hasent been released yet :-/. if it was i will be there in a flaaaaaaaaaash :D.
heat issue is a MASSIVE issue everyone has and i dont know how a software update will solve it?? heres to hoping eh :P.
the best way to get rid of bloatware is to root ur phone and download bloat freezer from the app market (what a god send). After freezing sooo many unused pre installed apps i can see my battery life has improved :P. however i have froze a lot and that includes the touchwiz launcher and everything associated with it.
Daz, ok good! I was already getting worried that I was using an an ancient firmware...
I read about 2.3.4 being released, but I never checked if it was for this phone, lol.
Vengance, doesn't rooting a phone mean that insurance won't work anymore?
How long can you guys play games without the battery dying?
Guys, I don't think (please do correct if I'm wrong) but isn't the poor battery life due to the fact Android 2.3.4 isn't optimised for dual core phones yet. hence 2.3.4 should resolve this?
That's what I've heard and certainly hope so. Otherwise 3 chargers is the way to go!
Yeah! To be honest, so long as it lasts me a day, I'm happy. Although the official battery extender looks pretty good for when I need it for a weekend or something.
Yes
my battery lasts a day so damn sight better than my Desire HD that lasted 10 hrs if I was lucky.
I did replace my SGS2 having had a day 1 phone that started restarting 2/3 times per day. Picked up new one last week and its been pretty much perfect.
Its running 2.3.3 ke7.
cheers. :) Mines coming on Monday after T-Mobile only got them in on Friday. So hopefully, mine won't have the that issue - which I'm guessing was something to do with the firmware they put on it at the factory or the hardware the "put together" at Samsung's factory.
the faulty phone was also running the latest f/w (I'd installed it through kies) ...
