Help The process android.process.media has stopped unexpectedly
dv310p3r
I've rooted the Connect. I'm getting the following error randomly.
"The process android.process.media has stopped unexpectedly."
I get this error for sure each time I open up the Google App Store or Google Play.
That happened it to me as well IDK how to fix it i got a new phone through warranty
But every time i downloaded something that would pop up
sorry i cant help
yea rooted and deleted bloatware i could use navigation but the market would shut down after every download and couldnt do flash settings
thats why i am hesitant to do it on the new phone
this is most likely happening because u deleted the stock metro web never delete that ever, as for the fix i believe you can adb push it back or wait till they have a working cwm and re-flash your phone.
another fix would be if you have not done the update to your phone do it now and it will fix that problem.
go to the all things root and go to whats safe to remove whats not and it speaks about this issue and how to fix it
That's what fixed it for me. When you go to that thread, just follow what it says. In brief, basically you're going to install a program that will reinstall all the default apps for you. It's something from LG.
It won't delete your data.
Thanks all!
Where is that thread. Can you provide a link? I really need to fix this phone after I uninstalled the metro web browser. I cannot access Google Play.
I am posting this to confirm that it is indeed the Metro Web program that causes this. After seeing the thread I went to Titanium Backup and restored Metro Web. Problem fixed. If you are removing programs without backing them up first you are, in a different boat my friends.
-CCC
If you didn't use titanium backup to bck it up, Google lg connect lg mobile update tool. Download that and when you put your phone in debug slash internet mode it will restore your phone. There is a thread on here somewhere on it.
I did a simple way, just found a copy of MetroWEB on the internet and pushed it back on my phone using Root explorer by setting the right permissions
