the screen issue while use the TP2 battery.
lioydran
hello guys
i have put a TP2 battery (MOMAX from hongkong) into my incredible
first it seems running good just a little gaps in the back. and i never mind as the reason of the large capacity.
but today,when the power reduced to 50%,the touch screen was became strange and hard to touch,and then just like a finger on the air which touched the screen (i didn't do anything) and the icon in the screen has move on itself (usually turn to left)
i was shocked and just think it was caused by the software issue.and decided to back to the factory mode and earse all of the data .after these work. the screen still uncontrol and move on itself ,it's terrible.
after all,i has put the tp2 battery off and use the OEM, all of the problem has gone and the screen are cured.
i don't know the other brand of tp2 battery would be lead the same problem or not.
becareful when you use the TP2 battery.
hello guys
If you remove the battery cover from the back of the phone (while using the TP2 battery), does the issue go away?
