You can see freaking pixels just when you zoom a little bit and i have 3 and 5 Megapixel cameras at home i can compare, end of story, it's not 5MP on Esteem, Just like MetroPCS isn't 4G
What it seems like is either your spaming or you actually have no idea on the technical side of things.
Which we can help you with.
Yes. The LG Esteem is a TRUE 5 megapixel camera. Just in case you do not know what megapixels really mean. To keep it simple, it simply is for print. So the higher megapixels you have the larger prints you can, print. And megapixels in regards on the computer or the phone is the resolution size. Why on your phone you see 5m(2592x1944).
Metropcs is and was the first cell phone provider in the U.S. to launch true 4G LTE. Sprint on the other hand launched WiMax which was not true 4G due to it's lack of speeds. It didn't fit the world telecommunications data speed guidelines.
Please make sure you understand what you're saying because it only makes you look like you do not know what you're talking about.
If you don't know please do not post information that is not true. If you want to inquire about what features are supported or want to know we'll do help you out.
But when you start tossing out information and info that's not even correct..doen't look good.
If you're phone is getting pixelated with our without zooming then its a hardware issue. More than likely your camera lens/hardware is defective.
Like I mentioned above. Just take it back and exchange it. It's that simple.
Just mellow out, I'm sure your upset because you caughed up a good pennie for the phone as well all did. That's why there's a warranty. Get a new one!
Cheers!
