matthewrocz
I need a build prop so i can install the apps i've purchased off Google play but their incompatible with our device. Im currently on CM 10.1.0
I've attached my current Build Prop if thats any help.
Thank you
Edit: I did the research and found the build prop for The S3 and renamed some codes to match up. now i was able to install GTA:VC with no problem.
View Second post for Build.prop
Thank you
