Help The usb storage
gayso
My phone is not rooted
I use a sd card
and as the phone has 11gb itself this is enough for me as i used it for apps music and pictures
now as i got it the sd card i want to keep all my apps on the usb storage(internal memory)
and i will keep the rest like music,pictures on the sd card
but i even realized that some apps go to the internal memory thats 2gb
My question is, how can i make it default for apps downloaded to be saved to usb storage, and how can i prevent them going to internal memory?
I use a sd card
A google search shows this and this... and this can be done without rooting your phone.
Just a reminder that there are consequences to doing this method - the removal or failure of your SD card can result your phone or your apps to be pretty unstable... once you get it installing to your external SD card.
Just sayin'.
