Root (THEME) - Blue Marble
elgecko
Here's a blue theme - Blue Marble - for the OE.
Flash in Recovery Mode - Install zip from sdcard.
For Leslie Ann's Harmonia ROM.
- Oceanus GO LauncherEX Theme
- Ocean HD Live WP
Only good for ROM version noted
Theme Blue Marble OE Harmonia 2.03ver1 - Corrected Signal.zip - New Icons / Blue text in status bar / Network Icons updated
Fixed For some reason the network icon does not change to the themes one. Not sure why.
Hey I used to use this theme on my Optimus V with Backside
Yep - Very close to the same as the BACKside version.
I updated the status bar text to blue and changed the icons with Ver1.
Not sure why the network icon does not change to the themes one....
The Elite's signal icons are named differently than usual.
The elites icons are named..
sprint_stat_sys_signal_0_white_cdma.png - White Icons, Not Synced
sprint_stat_sys_signal_0_green_cdma.png - Green Icons, Synced
There are 7 of each numbered 0 thru 6 for the different signal levels. Sprint Icons consist of 6 bars
The UOT themes are named...
stat_sys_signal_0.png - Not Synced
stat_sys_signal_0_fully.png - Synced
There are 5 of these numbered 0 thru 5 for the different signal values. Uot icons consist of 4 bar
So to make your theme work you need to rename the uot filenames to match the Elite's filenames. Since the uot themes are only 4 bars and the Elites are 6 you will need to duplicate 2 of the uot files to make up for the 2 missing icons
You need to end up with 7 files to make things work properly.
Or you can also pull the Elites icons from systemui.apk and edit them in Gimp to make them whatever color you want and then put them back into the apk
Edit.. Fixed incorrect filenames
Uploaded theme with corrected signal icons.
FYI these do not appear to be the correct files:
sprint_stat_sys_r_signal_0_white_cdma.png - White Icons, Not Synced
sprint_stat_sys_r_signal_0_green_cdma.png - Green Icons, Synced
These made the change:
You are correct... I goofed.. The ones I listed were the roaming icons which we don't use. I missed the r in the names.. Sorry and I have fixed my post.
