Root [Theme] Blueraider - Skyraider 2.2
djkms
Here is my first theme for you guys Blueraider. This theme is for the Skyraider ROM 2.2 Sense. I have taken every aspect that was green with the default theme and made it blue. I have gone through every single apk in the Skyraider 2.2 ROM and themed accordingly.
The list of edited apk files can be found in the text file in attachments
Installation Instructions:
You must be running Skyraider v2.2 Sense - This theme is untested on other roms and could potentially crash your phone.
In theory it should work with other 2.2 deodexed Sense roms from the 8/1 leak
DO A BACKUP!!!!(This step can be done from ROM Manager)
Copy the Blueraider zip to a directory on your SD Card
In ROM Manager choose install ROM from SD Card and choose the zip you just placed on the card
In the ROM Pre-Installation window put a checkmark next to "Backup Existing ROM" ONLY!!
DO NOT put a checkmark next to Wipe Data and Cache!!
or
You can install the theme from Recovery - Just make sure to do a Nandroid backup first
Thats it.
Known Issues:
Progress Sliders green - Fixed in 1.3
Change the Personalize Icon in settings - Fixed in 1.2
png file on the slider not fully transparent (defaulted to original slider until I can find a fix)
HTC_IME needs to be skinned
Version History:
1.0
BlueRaider is Born!
1.2
Fixed htcime FC issue
Fixed various .9 pngs
Changed a few icons around
Reverted back to the sense unlock slider
1.3
Progress bar now themed
What the future holds:
Integration with Super Circle Battery - done, download link below
Possible Integration with Smooth Sense Icons
Possibility to custom theme your apps/widgets with colors from this theme
Font changes
Custom colored apps:
With all apps please make sure to uninstall previous versions before installing the custom themed version
Blue Swype Keyboard
Blue Swype Download link
Credit goes to bilbobrian for supplying the apk to edit found here
Blue Lastfm v1.6.5
Last FM Download link
Hopefully within the next week I will be working on a pink theme for the ladies, stay tuned!
Download BlueRaider:
Latest download link at xda-developers.
BlueRaider Super Circle Battery Mod:
Credit goes to Worm for putting it together, Love the mod! (more info can be found here)
Download link
Stock Skyraider 2.2
Theme Only - Not the full ROM!
If you have installed this with success on other ROMS please let me know.
Comments, suggestions and donations appreciated!
Version 2 is now up for download over at XDA. I will not update this thread anymore due to lack of activity here. If you have any questions or need help with this theme you can still leave a reply here if you dont have a account at XDA.
