Root Theme building question
darkcyber
Android Expert
I am interested in trying to build my own theme and wanted to know if building a theme for any particular ROM is easier to do than other ROM's or is it basically the same for all of them?
It's basically the same...you just have to make sure what are you building will work with that ROMs framework. I suggest using an existing theme and tweak it to your liking...to get started.
