Hashtag
Okay, so this is a theme chooser for the Optimus Elite that I made about awhile back. You pick the theme you want, then push the button and away you go. Due to recent events, I no longer have any time for android projects. So I'm putting this out here along with other stuff I hadn't quite finished yet, and if anybody wants to use anything from it then that is totally cool.
The theme chooser .apk can be downloaded here- https://docs.google.com/open?id=0ByIGr8SqtN0cYU42X3NCWl9FMW8
The source for that(in case anybody wants to add more themes/functionality) can be downloaded here- https://docs.google.com/open?id=0ByIGr8SqtN0cMmFBUFl4NTlqYm8
The source will require actionbar sherlock as a library
Now, I had been making something for the new version of tagged that was a theme chooser with some other features. It's been awhile since I've messed with it, but I I had added a feature that automatically switched the functionality of the search button based on several preset options(as long as you are using the kernel that I made specifically for this purpose. That thread can be found here- http://androidforums.com/elite-all-things-root/652112-rom-modification-remapping-search-button.html). The last thing I remember doing with it, was I had begun to add support for installing beats audio(I realize it's just an equalizer, but some people like it, and I modified the installer from a different phone so that it worked on ours).
If somebody with the know-how wants to finish that up, the source can be found here- https://docs.google.com/open?id=0ByIGr8SqtN0cRFVybzFYTUplMDQ
That one needs actionbar Sherlock and sliding menu as libraries
I planned on uploading the unfinished version of tagged 1.2, but due to my lack of organization, I have like 50 different versions of tagged 1.2 in my ROM folder, all with different names and I have no idea which one needs to be uploaded(some of them are named "ragged" and "tayget", no idea why). So over Christmas break I'll sift through them and find out which one it is. I'll update this post when I figure it out
Also, hope you had a good holiday break!
