BIONICLE38
Guest
I finally installed hash tags Theme Chooser apk but when I install the ics theme and reboot everything looks the same, all it does is put 2 apk files in the root of the internal SD card.
One is
ics-framework-res.apk
And
Ics-System-UI.apk
And when I try to install them it says "failed to install" so what do i do?
One is
And
Ics-System-UI.apk
That was alot simpler than i thought lol.
