Root [Theme][CTMod 3.5/3.6] ET16's ICS Theme (5/7/2012)
ICS Theme beta 0.82 for CTMod 3.5 & 3.6
This isn't designed for 3.6, but apparently it works :D
I ported it to the Marquee here
I can't show it in the screenshots (phone's out of service), but the 3G/1X/Wifi/signal indicators turn blue like the battery color.
I'm still planning on making additional changes and fixes as I figure them out more.
DOWNLOAD
This is a CWM-flashable zip
ICS Ringtones
This is an optional package of the default ICS ringtones if you care to have them. It flashes them to System, but you can unzip this file if you just want them placed on your SD card.
Change Log:
0.82 (5/7/2012) - New accelerated scrollbar, dialed numbers glow when pressed
0.8 (5/1/2012) - Changed battery to include number, changed textboxes, fixed dropdown box, timepicker, and radio button sizes, changed toast notifications
0.7 (4/24/2012) - Fixed USB Storage image, changed QuickPanel icons/indicators, changed progress/volume bar to a thin blue line, changed CTMod logo in settings.apk
0.6 (4/19/2012) - Fixed Phone Dialer buttons, added shutdown animation, added system ui sounds & (optional) ringtones, added more screenshots
0.5 (4/17/2012) - First release
Known issues:
- "Connected" text lies partially behind the Dialpad button while in a call (Not sure why)
If you find anything odd or broken in this theme, leave a comment and I'll get right on it. Suggestions are welcome as well.
Bloodawn for CTMod, the APKinstaller.zip, and all the rest of his hard work on the Prevail
ChaseBroyles for catching the Phone.apk bug
justchilin for pointing out the USB Connected .png bug
Screenshots:
[old versions]
Version 0.7
Version 0.6
New update. See first post for details. I want your opinions on the new Toast notifications and battery indicator and whether or not I should change them back.
checked out your theme with bloodawns new ct update
nice job..everything looks good..menu option buttons seem a lil small for some reason but overall good work bro
like that bootani you added..i thought i was the only person who liked the nexus prime bootani
pop up menus
seems like they were kinda skinny..but very nice none the less..didnt know if that was a known issue or just me being bitchy
pop up menus
The buttons on the bottom are a little skinny... probably because I copied them right out of ICS instead of making new ones in Photoshop :D
So... anyone who dislikes the midget-buttons, try this:
Normal-Sized Buttons
(it's just the framework-res.apk, install after the theme)​
I'm stuck at a blank screen on my prevail. running ct mod 3.8. the start up animation shows and after a couple loops the phone vibrates once and then two times and goes to the blank screen. after which it keeps on vibrating ever so often.
This theme is for ctmod 3.5/3.6 its not designed to work with 3.8.
This theme seems to work awesome for me! I like it & think its a job well done! Thank you to the person or persons who hooked it up! Gotta keep these antique lol droids fun & looking good!
