Root [THEME] Cyense Theme for Odexed & Deodexed Sense 2.1 ROM
MazerOne
CYAN Theme for
ODEXED & DEODEXED
Sense 2.1 ROM
Works with :
JIKANTARU ROM ( Odexed ROM Based on Marvel HTC WWE ASIA 2.14.707.2 )
DSCPLX1 v1.1 ROM
( Deodexed ROM Based on Marvel S HTC Europe 2.26.401.3 )
Install with :
Rom Manager (install ROM from sdcard)
or into Recovery (install zip from sdcard)
NO WIPE
Don't forget to backup your current ROM before .
Mazer.one, although I recognize that there may be the wrong thread but I need you if you'd do me a favor? Can you give me a good design for the Rosie Drawer? I've only ever the stock Rosie I mean below the control panel and no Theme from XDA works with the 2.26.401.3 RUU. The best would be if it is transparent. I know that is the moment when Sense 2.1 wits. Thanks in advance and sorry for my english!
I'm working on it ...
I really like your theme, dude!:D
I'm not a fan of the Rosie MOD and I've got a small problem with the MMS MOD.
When I write and send a text, or when I read a text, it keeps the text unread.
I have to re-open the text to read it. I think the MMS MOD conflicts with the HTC text widget I use. Anyone else got the same problem?:rolleyes:
Can I (somehow) just delete the MMS MOD?
If I re-install the Cyense Theme ZIP, the MOD is gone? Or do I have to re-install the ROM again?:(
If you have 2.26.401.3 ROM, in the "Pink theme" thread, there is a link to return to stock UI, install this and after re-install Cyense theme without mms mod.
Ps: I don't think that your prob come from my mms mod...
Thanks!
Works like a charm
What ROM do you use ?
It's only for sense 2.1 !
It doesn't work with sense 3.5 and i tested this theme only with last RUU 2.26.401.3 , i don't know if it works with older RUU !?
Oh, I am using DSCPLX1 v1.1.
I was just wondering.. Now I understand.
Also found out why the clock does not work on my phone.
I am using the HTC skin called 'Steen' (Dutch, dunno the English name...), which is why the clock doesn't work properly.
The Cyense theme itself works perfectly, loving it!
