Root {Theme} Do Bluev1
ACD168
Android Expert
I'm sure there isn't a huge need/want for this as the new kernels just arrived and were all waiting patiently for unrevoked forever.
This isn't anything very special and I know there are too many blue themes out there, but this is a lighter blue, and it is for the stock 2.1 ROM.
If there are requests for this to use on other ROMs, I will port it.
this is my first go at a theme. let me know what you think.
Download link: Multiupload.com - upload your files to multiple file hosting sites!
Do Blue v2 - faded
I am working on making everything faded.
for now I started with just the rosie but I think it came out good, next will be the status bar, and then getting to the rest of the framework and getting to all the .apks that need to be edited.
download link: Multiupload.com - upload your files to multiple file hosting sites!
just worked on a 2.2 port, and came on a boot loop so I have to look into it furhur, update soon.
I like the themes you've posted so far, it's just I can't use any of them lol
I'm interested to see this on a 2.2 version soon tho. Keep up the good work! :D
Thank you my friends :-).
as requested I am working of a metamorph port of these to 2.2
Hey man , was wondering if you've figured out metaMorph yet? Im testing my theme, and no matter what i do MM never actually changes anything... it runs, it acts like it ... but it just dont go through...
it is for the stock 2.1 rom, and put it on your sd card like a rom, and apply from the menu install from zip in recovery and find it on your sd card :-), thanks by the way
