Root [Theme] GuysRedtheme for MegaTron 6.0.4 10/21/12
gkak
screenshot-1350790413369.png screenshot-1350790390677.png screenshot-1350795737146.pngscreenshot-1350790095345.png
this theme is for MegaTron 6.0.4
download https://www.dropbox.com/s/ahdr0t4u3epx3f8/GuysRed.zip
this is a uot theme so place it on sdcard, reboot into recovery, make a backup, wipe cache and wipe dalvik, install zip from sdcard, choose GuysRed.zip, reboot
this is an zipthemer (found in playstore) addon, which themes phone, contacts and deskclock
install zipthemer app, download
https://www.dropbox.com/s/a4u35vd31ztj8bd/guysRedAddon.zip and place it in sdcard\Zipthemer
open zipthemer app
open menu choose update edify hit the "browse" button next to 'select flashable file"
pick any uot theme (guysred.zip for example)
hit "configure' then back button
choose "+theme" and pick "guysRedAddon" then hit "Build it!" when it asks if you want to make an undo file choose 'always"
let it do its stuff then reboot into recovery
wipe cache and dalvik, install zip from sdcard, choose "guysRedAddon-update.zip, wipe cache and dalvik (yes cache and dalvik before and after flashing zip)
reboot, enjoy!
thanks to slayer for lighting a fire under my rear, chevanlol, mavrik, Bloodawn, xaelith, psycho4us4,niteNarmor, dont panic, upwardspiral and anyone else who encouraged, taught, allowed me to borrow images, etc.
requests are welcome
Looks good bro, I used your 6barstatusred.zip to recolor signal bars to light blue for my Blue Theme and then rebuilt it in Zip Themer and then flashed it in CWM and it worked flawlessly, thx again for turning me on to Zip Themer bro, I'm surprised they didn't make it a paid app cause it's well worth what it does!! lol! :p
glad it worked for u. i went back to 4 bars in my theme. i think it looks cleaner and does it really matter if ur getting 5/6 or 6/6 signal? now that I think about it for boost phones there should only be two text icons for signal "u have a signal" or "ur screwed"
just sent u some zipthemes, eye candy for ur blue and sunshine. enjoy
I wiped then installed the update zip i still dont have the green settings menu? Nice work man i like it .. is their any way i can change the color of the status bar to ics blue? :)not the background but the signal bars, 3g ect....
I wiped then installed the update zip i still dont have the green settings menu? Nice work man i like it .. is their any way i can change the color of the status bar to ics blue :)
Green settings menu is actually an app called "quick settings" from play store. I can make a blue status bar ziptheme. U want 4 or 6 bars? What style of bars? The "classic" or the one I made for my theme?
Hell yea man thanks!! I would like to have the 4 bars and the style you made for your theme:Deverything the same just singnal bars,3g-wifi,battery and time ics blue color.. If thats possible ? If not.. Ics blue battery signal bars with the rest red would look cool to.. Cant wait to see it:) Thanks again Bro..
here is ics signal https://www.dropbox.com/s/mk3t4ctze1rt158/icsbluebars.zip
I'll work on the wifi bars. I could also do the battery and 3g but not sure how to do the time, thats an xml thing. would have to start from scracth, first make a uot (which would do the xml for me) then do the rest. might take a while cuz im working on a green theme now...
Nevermind i got it looks awsome!! And take your time i know this stuff is not easy and i truly appreciate you taking the time to hook me up with this.. I might take some time today and check out some theming guides ect..
Now that's what's up!!! LMAO!! :p Nice job man... :p
EDIT: I got the zipthemes bro is there any reason why the application icons arent showing?? I've already tried clearing cache and dalvik-cache...
oops, those icons werent in the icon pack i was using. I emailed u some more generic icons from a similar icon pack
I think what I'm gonna do is download some themes from the Play Store then steal some icons from them... lol! :p
Been there...
U can look for cm7 themechooser themes in play store or google. After cm7 images become mostly hdpi or xhdpi
How do i go about making zipthemes like this one to use in zipthemer so i can change and color my signal bars?
unzip one of the zip themes and look around... there is an xml which tells zipthemer where to put the images. usually there are folders that have have subfolders that corespond to the place you want to put images. e.g. for signal bars it would be systemUI/res/drawable-mdpi
I cant figure it out:p Would you mind making me some regular ICS 6bars and some green and red ones? :D
