Retrokid223
I did not make this theme, im just posting it here to share
Download Link----> Invertnito For the DX!!! - Droid Forum - Verizon Droid & the Motorola Droid Forum
INVERTNITO Dx
Well Folks You have been very patient waiting or this!! I am Proud to say its finally here!
JsinLegasy and Bgill55 Bring you Invernito for the Dx
If you guys dont know Jsin he has been a long time friend of mine way back when we were themeing for CM together. He has had many great themes. Remember the Super hereo Series!!!
Since I didnt have The X I couldnt really theme for it and Jsin Offered to do it! (he is the only one I would trust to do this port) Let me tell the X is no fun to theme on! But I think you will be happy with this end Result!
Jsin did all the Porting to the X I did the XML work to get the colored Text right![]()
Advice from Seano: do NOT install this over the R2DX leak that p3droid has out because you will go into a boot loop as i did. it does install just fine over the 2.3.15 leak though.
