Root theme issue (round 2)
all roms make a sound for that, its to let you know the sdcard has been scanned and is working properly, and it has been mounted to the system, basically when you plug in your usb to your computer and select mass storage, when you unplug it, it goes through the same process to make sure its installed correctly and then mounts it to your system, leaving your phone on vibrate will take care of the issue, but iim not sure about the sdcard notification sound and getting it to stop
it lets me know my phone is fully booted up if im not paying attention to it, and i have done that many numerous times!
Thanks for the great explanation! :D
I know why it does it, I just don't want the notification. :D
Even the 3.4.2 leak had the option to turn off the sdcard notifications.
I pretty much have most notifications turned off. The less noise my phone makes the better. It's just a preference thing I guess.
Edit: Woohoo! I just gave out my 100th thanks! Let's party!
When it's booting up and initializing the sdcard it makes the notification sound. I know I've turned this off with other ROM's and it's usually in the sounds option in settings, but I can't find it in Fission. Not really a big deal, just would like to turn it off.
got ya....i hadnt ever noticed....course maybe cause i run fission a lot....lol....
Sorry guys.. things got extrememly busy at work over the past day or two.
Status update - I did a factory restore, and reloaded fission261. So far works great. I haven't put a theme on yet, just because of business. But it sounds as if things are working now. I should be able to theme it just fine without any left overs.
