Root [THEME][K2_CL][4.1.2][DEODEXED] Red Hot / Cool Blue
Lordvincent 90
Standard disclaimer: I am not responsible for any damages to your phone, reputation or employment status as a result of the use of these themes
Your system must be deodexed to use this theme. If it's not, visit this thread here:
http://androidforums.com/showthread.php?p=5980069
Red Hot
Hey guys, so i put together a little theme for you guys. let me know what you think. :)
Download Here
Red Hot Theme
To install, simply flash in recovery.
Optional Home Screen Setup:
here are the instructions to get your home screen to look like the screen shot:
http://forum.xda-developers.com/showthread.php?t=2025464
The thread is from the nexus 7 section, but it works for our phone
Cool Blue
Download Here
CoolBlue Theme
thanks goes to:
O_splatterhand for the quick toggles.
Guspeed for the base files i used.
Can you make a blue theme, that would be really awesome
Updated OP.
I was actually working on this already, but the hard drive just croaked in my laptop. The blue theme is more of i w.i.p. (Until i get a new hard drive) :)
Let me know what you think
Updated OP.
Uuum idk this has happened to anyone else but when I flashed the theme, my status bar disappeared .-.
Maybe a bad download? Try downloading it again... If it doesn't work I'll upload a different copy tonight :)
Has anybody tried this with the new .6 update?
I tried deodexing and it seemed to work but upon flashing the framework files my status bar would not show up
I couldn't get it to work with the newest build. I only tried once. Didn't bother trying to pick at a possible solution.
I haven't even gotten an update. As far as I'm aware, I'm on the current software/firmware...
Once i get my new hard drive (probably in the next week or so)
I'll restore my stock backup and see if i can update, and if so, I'll update my themes at that point :)
You know what I found out what the problem was and it had nothing to do with your theme I'm currently running the newest update and everything is fine
Well best I can figure is something went wrong with s-off and i didn't realize it until settings wouldn't stick and other anomalies...SO...I wiped it all and started fresh and it all went perfectly
Plus it feels better to clean house and start with new 64GB Sandisk UHC-1 card and nice clean blue theme with atom launcher and NO sense....not that I don't like it..i'm just a fan of free memory and free space more!!
Unfortunately I don't think our phones support UHC-1 speeds though, but at least its a class 10 so win win over a class 4
