MetroNoob
This ONLY ONLY ONLY ONLY works for ODEXED roms!
Hi, I'm back again.... xD
I found this theme, called the LG Revolution, it is the stock theme for the LG Revolution created by "Sisterbird". If you would like to make your phone something similar to the "Samsung Touchwiz", then this theme is good for you.
SystemUI - Themed for the status bar, and networking icons. If your status bar is force closing or does not show up at all, PLEASE download my UNDO zip or use or Nandroid to recover.
Framework-Res - Most of the system icons.
Settings - For the Colorful settings icons.
MMS - Changed the notification icon.
Desk Clock - (as shown in the pictures).
This theme is really cool, as I'm running it now, you will need to flash this in Clockwork Mod.
I did not make this theme, just for posting.. created by Sisterbird.
To flash more of her themes, which are here, Android Metamorph Themes - Sisterbird.com you will need to download ZipThemer (Alternative of the Metamorph which seems to fail on the Admire.) https://play.google.com/store/apps/...51bGwsMSwxLDEsImtlbGxpbndvb2QuemlwdGhlbWVyIl0.
Screenies:
Download Links!
Flashable ZIP (Highly Recommended) LG_Revolution_GB_MM-update.zip
Undo Zip, You can revert back to Stock Gingerbread if you do not want to 'Nandroid' LG_Revolution_GB_MM-undo.zip
If you want to use the original download link you will need to use ZipThemer to flash this Image. Once again, Metamorph doesn't work, or doesn't flash the entire thing at all.
http://www.sisterbird.com/android-themes
Screenies:
Download Links!
