Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
I don't mean to sound nooby but, does this work with BrokenOut? And if it does, do I wiped cache and flash it? Will all my applications still be on my phone?
Any zvd rom. So if your on zvd than yes. I did not wipe anything and it came out fine. Wipe cache if you wanna make sure.
And aslong as you don't wipe data, your apps will be safe.
Um wtf lol jk
Wow how did that happen? lolol
Hey ldrifta, what files gives you the CRT animation? Policy.jar and some framework pngs?
that my friend is literally as easy as flipping your light switch on in your room lol
decompile framework, in the values folder is an xml called 'bools'
in that xml you will see a item in the list called like screen off animation true, just replace true with false and there you have your crt animation lol already pre-built into the OS for some reason lol
He did say he was starting from scratch:eek:
This is test #1 yes:confused:
not exactly from scratch lol im just pretending i am.. i kept all the images and i will of coarse fix them up later to match, but i started all over with the xml files.. re-did all of them. for every app in the theme. lol almost done, still want to see what mods i can add before i start worrying about image files yet..
dude how the hell are you so awesome at this? AWESOME theme!! i have a few questions about how you accomplished a few things in here.
First...how did you get swype to clear in the dropdown menu? did you pull it from a cm7 rom?
second...how in gods name did you get the music and download provider colors to change in the dropdown? I downloaded the Google music app from the market and totally removed the stock music app from the rom and the text color when playing music stayed blue???????? wtf? I have never been able to successfully change the text color in download provider or music and compile without an error.
third...whats that crazy circle thing doing in the dropdown when im downloading something?? lol did you do that on purpose?
oh and i have one problem...lol...i use ADW EX and when i go into the launcher settings the background is transparent so when i click on something and another window comes up i can still see the previous one behind it...so i just see text on top of text on top of text the more windows i open. I wouldn't expect you to change your whole rom because i am using a different launcher but i would like to know how i can fix it myself??
thanks again for the great theme :D
He still making adjustments to it at the end those things will likely be fixed :D
thanks lol and i have a few answers for you!!
to answer your first question about swipe.. this is how.. [HOWTO]Implement Swipe to Remove Notification - xda-developers lol
second.. for downloads just need to decompile downloadproviderUI.apk and edit statusbar_expanded xml
same thing with music.. lol
third.. i dont know.. that was an accident a while ago and have no idea how the hell i did it but its not supposed to do that lol
4th, to change that you decompile framework, then in values folder open colors.xml and change black from this #70000000 to this: #ff000000 and you will have your normal black background back :D
Dude thanks a lot man!
I have been trying to get a dark transparent background like that for the contacts apk. (Like when you are viewing your contact list) where is the background in apps located??
Oh and about the text color in the dropdown for playing music. I downloaded it right off the market so the text color should have been black right? That's why it was weird to me because it stayed blue in the dropdown?? How?
Oh and do you have to change any XMLs to get the volume sliders thin like that?
So many questions!!!
there no actual background file for the apps list, it just an xml file with set color value as black, which is why i changed black(#ff000000) to transparent (#80000000) but for contacts and stuff im sure it's a similar set-up.. but when you do that it gives you issues like what you experienced with your launcher.. so it's tricky.. some things you can alter and some you cant.. once i find out how to do it with just the launcher i will put that value back to normal so people wont experience that issue.. lol
and yeah for the music thing im not sure.. it's all i did anyway.. maybe the app had itself set at blue nyway lol or maybe it just uses the default settings for rom which is best!!
Yeah i see what you mean about the background...ill see what I can do though and let you know what happens.
And hopefully that is the case with music cuz that would be pretty sweet!
Check this crazy ish out.
I'm seeing both menus when i go into a secondary settings menu. Eg. Pic 2 poweramp 1st settings menu pic 2 headset settings in power amp. 1st pic is lightflow. Wierd huh. I think it happened from test 1-2? Not sure tho.
Yeah this is exactly what i was talking about a few posts up lol. it will be fixed in later updates though so no worries.
WT-just mixed my first lemonade;)
EG?
