Root [THEME] MTDEV Ultimate ICS build 20120831
G
g60madman
Guest
README:
You asked for it, now you got it! The MTDEV Ultimate ICS Theme for CM7
MTDEV would like to inub, and his friend John for sharing the original Theme.
DOWNLOAD:
http://dl.mtdev.us/CM7/MTDEV-Ultimate-ICS-20120831.apk
MD5: 534cee9aee54181060203cad243df95d
INSTALL:
Run the apk from your SD card to install, and choose from the Theme Launcher
RECOMMENDED LAUNCHER
Holo Launcher
RECOMMENDED SCREEN LOCK
Holo Locker
CHANGE INDICATOR COLOR
Setting < Cyanogenmod settings < Interface < Notification power widget < Indicator Color < #33B5E5 < click the center blue button to accept
DONATIONS:
Your donations are very much appreciated. All funds are strictly used to help better MTDEV releases be that website or workstation upgrades for all Team Members
Screen Shots
Good job guys! I just installed it and it looks fantastic!
Thank so much to the MTDEV Team for all you do for us in making this phone not only usable(because let's face it. out of the box it's and overpriced piece of garbage), but pleasant to use! :)
I had an awesome idea for once! Thank you guys for putting that idea into action! This theme is so awesome it looks like it could be sold on the Market! And, let's face it, we all though of this! Excellent idea! MTDEV team thank you for putting a great idea into motion. BTW, I cannot take any real credit for it, but I am honoured to have played a part, however small, in creating this thing (just by suggesting it). This will definitely hold everyone over until CM9.
Thanks Mike for the suggestions. I will updating it some more as some of the layovers are a little weird like when searching in the store, or using the browser. Also I need to fix a lot of images as they are desgined for MDPI when I decompiled the apk. So I need to reconfigure for HDPI so it's higher resoultion and more crisp. I will get some more updates out soon!
Also if anyone has more suggestions let me know. By the people for the people :D Oh I will be updating the USB screen as well I like the one from CynoCream better I forget to add that.
you never take a break! lol..glad to have you around
Well our community is now demanding more of time. It's all because my Wife just got a Triumph LOL.
:party:
So now I just gained more support from SWMBO :D:D When she tells me to theme, then theme I will. When she tells me to code, code I will :D:D
@dsmyder I highly recommend getting your Wife a Trimuph as well, from one husband to another LMAO!!!!
yeah, the way it does searching the Playstore really bugs me. I was really hoping you had addressed that one in this.
And I agree on the USB screen too.
One other thing...
instead of changing the Notification bar indicator colors, as suggested in the OP, I recommend just turning them off. The Icons already have indicators so they are redundant.
edit:
well on reboot, I see they have reverted... damn.
I loved those icons :(
I really like the holo locker, but I use a PIN to secure my phone and those seem to conflict. Anyone know how I can get holo locker to work and use a security PIN?
Small suggestions:
-Change Play Store Header colors under "My Apps" from green to blue
-Replace somewhat ugly battery icon with battery icon from Cyanocream (but some people like the old battery icon, so I suggest creating a separate theme with the old MIUIish icon)
-Make the menus for the browser and other apps transparent like in Cyanocream (those menus that popup when you press the menu button)
-Create a theme chooser preview of the theme
(I will add more as I think of more!)
Things that should stay:
-the simpler notification toggles
-the transparent menus in areas like system settings
P.S. be sure to show your wife this theme when it's perfect, I am sure she will love it!
It's not open source, so we can't really do anything. Maybe email the developer with a feature suggestion? Look for their email in the Play Store. :)
Small suggestions:
I agree with all this
I'm loving the holo locker and the mtdev ultimate Ics theme :) and thank you for keeping this phone alive (the mtdev team)rocks!!!!!
I wouldn't mind a circle mod, something like this, but don't do it only on my account, only if others are interested.
G60 you're the man! Awesome theme! I run into couple of issues that might just affect me b/c i'm running 360 and its android 4.0 theme.
1. When I open the T-Mo Theme Chooser, MTDEV theme preview is missing (or should I say black).
2. I get the following error when trying to apply the theme: sorry, this theme is missing assets for your device's screen size. I hit Apply anyway and it did apply the theme
3. Everything looks great except for the power control widget where icons are blurry.
I absolutely love the battery life icon. I kept wondering how can I replace the standard icon with the percentage after seeing the Battery Widget? Reborn! Beta icon.
I like this but i think the power control widget should be stock CynoCream (or transparent), the facebook widget should be black, and the circle mod battery color is the wrong hex. I have a transparent png for power widget if you're interested.
yes this!! code android has this in thier ics roms and i would love to see it instead of the other one bc the hex blues dont even really match thats why i use a miui charge bar but this would be great if possible
Is anyone else having an issue with this theme where half the screen will sometimes go black when popping up the keyboard? Not sure if I'm explaining it well. For example in Dolphin when I hit the search but the screen goes black and I can't see what I'm entering, just the keyboard. Might be an issue with Swype, although this doesn't happen to me when using other themes.
Thanks
Thanks
I have also experienced this. When typing in Dolphin.
It also seems like this theme may be causing a little more battery drain than the default theme in MTDEV CM7. I'm not 100% certain on that. But it does seem like my battery has been draining a little faster since I installed this. Anyone else experienced this?
while im currently not running this theme ive seen a few posts inculding i think 1 from g60, it seems that theres a small bug on basically all search boxes, where the box isnt visable but you can still type and it'll count, you just cant see it lol
