Root [Theme] NexTheme for Fascinate 2.1
Status
Not open for further replies.
D13
Android Expert
This is not the NexTheme done by frostman89 from xda
Unlike the theme by frostman89 this theme also includes themed apps.
I basically rebuilt this theme from scratch.
Credit goes to:
-Manup456 (for NexTheme)
-frostman89 (for parts of his framework-res.apk and twframework-res.apk)
-jt1134 (for his deodexed system apps)
I am not responsible for anything that happens to your phone
I haven't tested this on a phone other than mine...so let me know how it goes:D Please:)
Screenshots
Download Link
Sorry I had to pull it, the camera was force closing
How do you install?
How do you un-install?
What are the prerequisites to run it?
If a user like myself was running ADW Launcher would I need to disable/uninstall it?
What about users like myself who use Titanium Backup, how would it work if TB backed up the apps and then I uninstalled the theme later, then did a restore using TB...i assume this would cause issues?
Thanks
How do you install?
Thanks
oh right I guess I should of mentioned how to install:D
just put on your sdcard and flash through clockwork, no need to wipe data or cache. And make a backup first
uninstall? just restore the backup you had previously made
adw? no it doesn't touch the launcher
you shouldn't restore system apps anyways...so it won't affect anything
oh and you just need clockwork to install.
Status
