Disclaimer: Do this at your own risk. Always have a backup. If you brick your phone, don't blame me.
Thanks goes to b_randon14 for the deodexed template and KBanause on xda for the color tutorial. Also thanks to Cuttalott on droidforums, I used a bunch of icons from his pink glass theme.
What is themed:
Notifications status bar and notifications--pretty much most of the icons are now themed.
Lockscreen
Android digital clock on the lockscreen - thanks to dhiru1602 on xda
Dialer
Contacts
Includes the v1.1 reboot/recovery options on the power menu and the %1 battery.
Instructions.
1. Must have b_randon14's deodexed template installed. If you don't have it, here's the link:
http://androidforums.com/triumph-all-things-root/405899-theme-stock-triumph-deodex-template.html
Also here's the link to the complete stock deodexed ROM from b_randon14:
http://androidforums.com/triumph-al...dex-roms-triumph-wi-fi-works.html#post3201169
2. Download and flash the theme here:
https://zipsend.com/download/bHlBTk...1UQw/0963cd286632b762d1206c547d314fc0cf17e8be
Here's screenshots:
What is themed:
Lockscreen
Dialer
Contacts
Instructions.
Here's screenshots:
by the way what image editor are you using?
I'm cheap so I use an app called Pixelformer to color the images.
