Root [Theme] PORTED COMBO Gingerbread BLUE/RED from Liberty 1.5 for ApeX 1.4
Brav1111
I honestly don't know if this is a good idea or not, so currently it only updates the framework (notification bar, etc). If I get good feed back or if I like it I will expand it to other APKs.
This is a combo of the BLUE and RED gingerbread theme. Basically I just went every other icon, red and blue. Basically your icons might change colors depending on your signal, 3g usage, etc.
This theme is for Apex 1.4.x
The main credit for this theme is the Liberty Crew. I believe this theme was created by draya1986. Great overall work guys.
[ROM]One small step for man one giant leap for --- Liberty 1.5 2/2/2011 - Droid Forum - Verizon Droid & the Motorola Droid Forum
This is a partial port of the Gingerbread Blue and Red from the Liberty 1.5 toolbox. The following apks are modified:
framework-res.apk
The usual warnings apply:
Use at your own risk.
I am not responsible if it hoses your phone.
Install normally:
Download to SDCard.
Boot into recovery.
Install zip from SDCard.
Blue/Red Bar Battery
If people like it I will add bhmstuff's circle batteries once he finishes the red ones.
