Root [Theme] Smoked Glass (Ported)
cortland1998
Thanks to olta777 and this thread.
Here is a them I ported for our Incredibles. I will be adding on to this theme but thought I would give you guys everything I could from the port. The rest of the files I will be creating myself over time.
I ported all I could from the original files, and still found there was a lot to add. So, incorporated it into my theme.
You can download it here: http://androidforums.com/roms-incredible/115344-theme-blu-incredible.html
So, I am rooted with 2.2 and Update. How are themes added? Do you choose update from zip file in clockwork mod?
I know you havent added the 2.2 yet, just trying to understand once you do.
Oh, and can this be used with Sense?
Thanks
Thanks
It's for 2.2. Download the file, plug in your phone to your computer, run the program. Follow the instructions when prompted.
if you are not sure how to install this
  • 1. download file - make sure USB Debugging is checked 2. boot into recovery 3. go to partions menu and then select mount system 4. Double click the exe file from step 1, make sure it extracts to your SDK folder, default is C:/SDK if your SDK is somewhere else, browse to it. 5. Just follow the instructions that pop up next
I saw mention of myself (olta777) and felt honored!!!! Thank you! ;)
I love smoked glass theme, so if you can get it working on 2.2, there will be many happy campers. :p
