Root Themes Choser for BACKside
brotherswing
Android Expert
I've figured out how to make apk themes compatible with Theme Choser with Uot kitchen. I'm ironing out the details and will edit my Uot tutorial with the new info in the next day or two. JD is starting to sleep more than two hours at a time, so I should have time. If I'm not passed out. :rolleyes:
are you going to be transferring a version of quicksilver to BACKsides theme chooser? it would be more comfortable applying themes from there
Yes, I am. I'll be maintaining both versions because the apk is easier to apply and won't need the constant updates, but the zip themes affect more of the system.
