Help Themes for moment
mywhip
Member
I want to get a theme change for my samsung moment but i need to know two things.
How is it paid for?
Will it stay on there no matter what i do? Say i change my theme to all black. No matter what button i hit, will it stay black? I have sweeterhome installed, but when you hit the home icon it goes back to stock.
There should be an option to set the default home. You might need to go into Settings<Aplications and remove the home defaults.
there is an app that is called "home switcher" i believe. it works pretty good to allow you to switch between your stock and installed homes. at one point i was using 4 different homes with it.
So is that pretty much the same functionality as the SenseUI "Scenes" on HTC's phones? (Hero, not sure if other HTC Android phones have SenseUI yet.)
Try adding the word "full" or "paid" or something to the search terms. Its hard to seperate the wheat from the chaff sometimes.
Not exactly. It works the same but whatever wallpaper you have set is the same in all homes. You can change the skin and icons etc. But if you change wallpapers they all change wallpaper.
So far this is what I have on my phone.
