Root Theming of OMFGB
bhmstuff
Hey everyone! Can any of you point me in the direction for customizing the themes for this ROM? I'd like to spend some time doing things with it, but the most I've done is change some icons within Apex.
Thanks!
Thanks!
Themes that work on CM7 should work fine with Theme Chooser.
Yep, it's all built on the t-mobile theming engine.
I applied the Honeybread CM7 theme last night. Works great.
I mean, to make a (or modify an existing) theme. I know there are themes out there, but I'd like to work on my own.
