Help Think Anything Can be Done to Strengthen Vibrate?
Jethro
Wondering if there are any creative ideas/hacks/apps that can make the vibration on the Eris even a little more noticeable?!? I think it's fair to say this is a VERY weak vibration feature, and a lot of folks have a hard time feeling it vibrate when a call or notification comes in.
I'm assuming it's a hardware thing, but thought maybe there are some creative workarounds.
I really like most everything else about this phone, but I cannot feel it at all when it's set to vibrate, so I'll definitely be missing calls & texts when carrying it around on my belt (or even pocket) as it's usually in vibrate mode then.
I couldn't agree with you more, and it could turn out to be a deal-breaker for the phone. I would love to hear any thoughts or suggestions.
Argh. Missed a couple calls and texts today because I couldn't feel the vibrate at all. I actually 'heard' it finally as I was crouched down in a very quite office, but still did not feel it at all. As it is, I don't think I'll ever catch a call or text on vibrate mode. This is a problem!
- Anyone know if the vibrate is a hardware function?
- Could it 'theoretically' be slowed or have the oscillation frequency changed in some way to make it more noticeable?
- Any belt clip cases or holsters that you have found do NOT deaden the vibrate even more? I still need to get a proper case if I keep this, but I currently have a nice clip on faux leather case I'm using on the belt.
I'm having the same problem and this might force me to return it. I literally can't feel this thing vibrating at all. While I'm at work I can't have the sound on so I end up missing any and all important calls/texts/emails.
I thought vibration strength is something most if not all phones usually let you adjust. I am hoping they add it to the settings in an update. I would actually like to disable the vibration the buttons below the screen make. They feel too rough for me.
I'm using dgalert classic and made my vibrate a constant 10 seconds...and I still cant feel it in my pocket. The vibrate feature almost makes this phone unusable..
Yikes, that's not good. Is dgAlert just for SMS/MMS messages? Can it (or anything else) customize the ringer vibrate?
I have an app for notifications called 'Missed Reminder' that allows totally customizable vibrate patterns, but I think it's still too soft, and this only works for notifications AFTER the original call/text.
I actually found a crazy bluetooth bracelet that you can wear that vibrates when you get a call, but this is pretty funky. I would be willing to carry around some small device like that in my pocket, though, if it was simple/cheap/compact. Anybody know of anything like this???
Thanks.
Ok, I've made my decision, sadly, to return the Eris. I can't decide which was more of a deal breaker, the weak vibration or the terrible battery life, but they both drove me crazy. Back to the curve for now. Let's hope in 4-6 months there will be a better option out there. Went and played with the Droid only to confirm why I chose the Eris. HTC almost got it right...
