Think I found 2.2 on HTC's website
Status
Not open for further replies.
If you did the unofficial 2.2 upgrade, I would seriously not try manually upgrading with the official 2.2 file. HTC has to do a special upgrade for us unofficial people.
so, this is the older leaked update, correct, NOT the one that just came out a few minutes ago?
The latest one (sorry if I confused you).
Note the differences in the filenames
Older Filename - OTA_Supersonic_3.26.651.3-1.47.651.1_releaseu2cqjc2e98n4o6xn.zip
New Filename - OTA_Supersonic_3.26.651.6-1.47.651.1_releasem24cfnusi9dsrr6i.zip
I'm not in a hurry, I'll wait for the OTA to be released, and still wait till next week, just to make sure everything is working fine before I take the plunge.
I downloaded the file from this thread, renamed it update.zip, moved it to my SD card, and so far it's "verifying update package". Will update here if it is successful or fails.
Edit: finally came up with "assert failed: apply_patch_check....." E:Error in /sdcard/update.zip (Status 7)
Status
