think im asking the impossible
bingo67
Hi,
I have recently bought a rear view mirror for my car which has the ability to use a rear view camera (which i wired up and is working great) and it has another lead that can be connected to such as a dvd player so you can watch movies etc on the screen inside the mirror. the cables are marked AV1 and AV2. AV2 is being used for the rear view camera and AV1 is the spare cable. My question is.......is it possible to wire my S4 phone (either via the 3.5mm headphone socket or via the micro usb connection so that i can view google maps sat nav on my phone through the AV1 cable to the mirror. I should point out that the connectors on then ends of the AV1 and AV2 cables are 3.5mm female sockets.
Any help with this would be greatly appreciated
Maybe you're not asking the impossible. Check this out _http://www.shopandroid.com/htc-av-cable/5A205A7232.htm
