Third Party Widget to Control Mobile Data
Brian Rubin
So when I was using Sense, there was a widget that could turn on and off the mobile data in order to save the battery, which I would use at times away from a charger for a while, like conventions and such. However, since switching to the amazing Launcher Pro, I no longer have access to this widget since it's an HTC widget, apparently.
So I've tried several widgets, and am currently using Power Control Plus because I like that it can go vertically. However, in every widget I've tried, none of them properly control mobile data. They either do nothing, or turn it off but not back on, for example.
So my question for y'all is, is there a good widget out there that can control mobile data reliably like the HTC widget, or will I just have to keep holding down the power button?
Thanks in advance for your help.
