Help This dhd is driving me BANANAS!!!
peterjmay
My phone keeps reloading the widgets and keeps getting the white htc screen p and then a loading bar before i can use the phone again...
So
If i do a factory restore what do i lose bearing in mind i have a sd card..
Am i write in thinking that if an app i have on my phone is not on my sd card and i factory reset the phone its gone for good?
If you have your contacts, diary etc backed up to google and your music and photos etc on sd card them very very little. I did one a while back and all I had to do was reload my apps from market and sign back into my accounts. My wallpaper was remembered but I had to set up all my shortcuts again.
Download SMS Backup and Restore and that will save all your texts too to Google account if you need them.
Your apps should still be listed under 'my apps' in Market so you just reinstall.
Thanks, i downloaded sms backup and restore and it says its backed up the txts, do i just restore these when the phone has been reset.. Will the txts still be on that app ready for me to restore?
When i reset it do i have to remove the sd card or does it not matter
No, Factory reset doesn't touch SD card
What about all the wallpapers and any graphics ive downloaded. Will i lose them?
They should be saved to your SD card
Yes, SMS backup and restore saves them to a folder on your SD card
If you first disable the google backup it wont restore them, otherwise it may attempt to restore them when you next sign in to the market
Also worth enabling USB debugging mode, if you haven't already and install "My Phone Explorer" on the PC. This is a great free tool to back up all contacts/texts/apps and memory card content.
