HaTrEd360
Android Expert
So I wasn't able to switch to Verizon yet so I need this phone working.
Okay, so i'm S-off. Hboot 1.04. Latest firmware and radio. I'm running the latest PAC version for the Evo V.
My issue started today as I noticed that I can slide my statusbar to change the brightness. That setting was off in the settings but I could still do it. I turned it on, the statusbar crashed and would not show back up. I turned it back off and it still wouldn't come back up. So I went to reboot and hit recovery on accident. Then just hit reboot system now in Recovery. Then the phone tries to boot. Passes the splash screen, goes to the PAC boot animation and freezes after the battery charging light comes on after a few seconds. Then it completely shuts off and turns on. Goes to the splash screen. Back to animation. Then does it again. And again. I go into recovery, wipe cache and dalvik, then go to Fix Permissions. I know that takes a while. Like 15 minutes later I come back to my phone. Still fixing permissions. Shouldnt take that long. Then it shut off again! So I pulled the battery and tried a reset by holding the power button for 30 seconds while the battery is pulled. Didn't work same result. And went to the splash screen, animation. Then says it's optimizing apps. It gets to 75 out of 150 and freezes then reboots. Gets to it again and this time it freezes at 40 out of 78. (I'm assuming because it already optimized half of them?) So it reboots again. This time it optimizes the rest and boots up! And after 5 minutes or so it shuts off again! Ugh. I'm now doing a backup. I've already been in a bootloop on this ROM twice in the past 2 weeks and had to fully format. I don't want to again, and I dont know if this is system or data related or boot related or battery related. Looks like recovery is working now tho as my backup is going fine.
I'd prefer not to have to RUU but if I have to then all well.
Anybody have any idea what's causing this? My battery does have some reading issues. I had 46% earlier, rebooted, and it showed 8% then. I went into recovery and it read it had 55% tho. Maybe I have a defective power circuit?? I also have Fast Charge on in the settings under Performance Control and Kernel Settings if that does any negative effects at all, just for some info.
I believe I need your help Prinny, Brian, or Ramjet. (Although we haven't seen you in some time. Hmm.)
