no. you can be unlocked while s offAnd I don't need to relock the bootloader before running an RUU because i'm s-off right? A lot of guides say I need to do that. I find it funny how every time I flash a different bootloader the version number changes but still says Unlocked at the top.
this is RUU mode,looks like youve figured th is out allready.youre stuck there becasue of youre failed flash attempt. youll need to successfully flash something and it will let you out. typically id suggest a recovery,wich is relatively harmless.Now because it failed, it shows a black htc screen with exclamation points in the corners.
yesCan I flash this through fastboot flash zip?
no. nothing to do with main version. youre s off and its not doign any security checks.Could it be a mainver problem? Idk what to do. I'm on the 2.95 OTA but I installed it through Ramjets firmware pg86img.
correctAs far as I knew adb didnt work in bootloader?
radio configuration. i thot it was sticking on system? any trouble with the radio or support firmware is typically a very bad signWhat is rcdata? Can I just remove that from the RUU and maybe it will work?
bootloader is fine,its doing what its supposed to to(keep you in ruu mode until working software is successfully flashed). it let yuo out of ruu mode when you successfully flashed the new hboot.Bootloader won't read the PG86IMG.zip on my sdcard either. I think my bootloader is corrupted. Can I flash one through fastboot? Ive been on administrator permissions this whole time on Cmd too. It said I had access denied when i tried to flash hboot through it
Anyone know how to check the file system on HTC through CMD?
c:\miniadb_shooteru>[COLOR="Red"]adb shell[/COLOR]
~ # [COLOR="red"]dmesg | grep mmc0[/COLOR]
dmesg | grep mmc0
<3>[ 2.973723] mmc0: No card detect facilities available
<6>[ 2.974150] mmc0: Qualcomm MSM SDCC at 0x0000000012400000 irq 136,0 dma 18
<6>[ 2.974333] mmc0: Platform slot type: MMC
<6>[ 2.974455] mmc0: 8 bit data mode enabled
<6>[ 2.974638] mmc0: 4 bit data mode disabled
<6>[ 2.974730] mmc0: polling status mode disabled
<6>[ 2.974852] mmc0: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
<6>[ 2.975035] mmc0: Slot eject status = 0
<6>[ 2.975127] mmc0: Power save feature enable = 1
<6>[ 2.975310] mmc0: DM non-cached buffer at ff007000, dma_addr 0x570ac000
<6>[ 2.975432] mmc0: DM cmd busaddr 0x570ac000, cmdptr busaddr 0x570ac300
<6>[ 3.099577] mmc0: new high speed MMC card at address 0001
<6>[ 3.100005] mmcblk0: mmc0:0001 KLL00M 2.25 GiB
mmc0: failed to get card ready
mmc0: reinit card
mmc0: Starting deferred resume
mmc0: Deferred resume failed
I think i'll worry about it at another date. I bought a Kyocera Event for 54 bucks as a temporary replacement lolol
