nu2android
and what does flashing a rom mean?
Or any one of these threads may have an answer:
http://androidforums.com/evo-4g-all-things-root/178790-how-do-i-install-rom.html#post1603012
http://androidforums.com/evo-4g-all-things-root/168413-rooted-i-think-can-i-check-how-install-rom.html
http://androidforums.com/evo-4g-all-things-root/163043-trying-install-roms.html
http://androidforums.com/evo-4g-all-things-root/142134-how-flash-custom-rom-if-you-rooted-unrevoked-3-a.html
http://androidforums.com/evo-4g-all-things-root/175912-chrome2phone-doesnt-work-reflashing-rom-complete-flash-process.html
http://androidforums.com/evo-4g-all-things-root/175635-how-do-you-flash-rom.html
http://androidforums.com/evo-4g-all-things-root/133239-flash-new-rom.html
http://androidforums.com/evo-4g-all-things-root/125168-i-rooted-unrevoked3-ni-how-can-i-flash-roms.html
http://androidforums.com/evo-4g-all-things-root/124986-how-flash-custom-roms-kernel-over-unrevoked3.html
I couldn't help but laugh at this reply.
Put the ROM on the root of your SD card.
Boot into recovery
Create a nandroid backup (in case you need to go back for anything)
Go to flash zip from SD card > choose .zip
Find what you want to flash
Follow instructions
Question... I read all kinds of posts. I finally rooted using Unrevoked. Now why wouldn't I only use "ROM Manger" to do things like Flash a ROM, wipe, or do backups?
The ROM Manger app seems like the easiest way to do all these things.
What I'd really like is a good set of instructions on Rom manager, or a good video. The ones I have watched seem to be taught by geeks with severe ADD on speed.
Is ROM Manger the way to go from this point forward? Any down side or limitations?
aFTER I FLASH THE ZIP, WILL IT GIVE ME INSTRUCTIONS TO WIPE OR DO I NEED TO DO THAT BEFORE FLASHING THE ROM. IF SO, WHAT DO I WIPE? DATA?DALVIK? CACHES?Put the ROM on the root of your SD card.
Boot into recovery
Follow instructions
